Weekend driver for the most part...
Why is it not a top notch restoration?
The seller speaks of it being a nut and bolt restoration, I disagree. I realize the term restoration means different things to different people. But with that said, here are some things I noticed right away:
-The front of the radiator support is not blacked out, it would have been from the factory.
-The grille and pieces around the headlamps aren't finished properly.
-Whoever did the exhaust system didn't even bother to use a proper hanger for the driver side muffler. The welds aren't very good nor are they correct for a proper restoration, not to mention the hedders and mufflers they chose to use. And who paints their mufflers black?
-You'd think for the money the seller is asking they would have prepped and painted the driveshaft or at the very least cleaned it.
-Rusty hardware on the rear leaf springs, and other areas.
-LCA's and tie rods painted black.
-I didn't care for how they painted the underside of the car black and did so without first removing all surface rust and caked on dirt/oil.
-The backside of the radiator looks as though its in pretty rough condition.
-They could have at least installed spark plug boots (at the distributor cap) that looked somewhat correct.
-Poor paint coverage in the trunk area, plus it appears that they painted right over the trunk latch mechanism.
I could go on but this should give you a pretty good idea of what I meant when I said it's not a top notch restoration.
If you're happy with the car and the price, go for it. Hope it works out well for you.
