GearAddict
Surprise you didn't mention this thread, lots of good input from super-bee and HT413 among others on 451's :headbang:
http://www.forbbodiesonly.com/moparforum/showthread.php?82619-My-BUDGET-451-build-finally
thanks I've been reading through Hts thread, definetly got me thinking about a 451
Don't know if you would be interested but I have a 69 dated 383 h.p. motor with 906 heads I'd let go of it and the box of parts for $500 ,there's a crank and water pump housing I belive some brackets and pulleys, oil pan, pistons and rods are there no intake valve covers or carb I can get a parts list if interested good block and heads crank looks good too .p.m. if interested
I'm on the other cost in fl. About 3 hrs away good luck ether way
Much thanks for the offer but if I'm rebuilding a 383, I'll most likely use my current core
It shouldn't cost you any where near $900 to change to a 3.55 or 3.23 if you already have the Dana 60!
I wish that were true... Maybe it's my ignorance on Dana's but the 2 reputable shops I spoke to say that the carrier has to be changed to get the gearing down that far (from 4.56 to 3.55 or 3.23)... I was quoted 1,200-1,300 parts and labor.... if someone knows different, please let me know
Find a core 440 they range from 2-500 bucks around us. Put some flat top pistons in it some decent rod bolts, balance it well and run a quality balancer on it also deck it so its not down in the hole, put a decent aluminum head on eddie e streets, stealths, garlits or even hughes prepped 915s run a decent spring on it a small roller cam and be done with it. Sell the rest of the parts you have for the b motor. This can be done easily for 5,000 bucks.
I like this as an option...hmm
One thing you all could help me to understand is what I should expect to spend with a machine shop for... A. standard machine work for a big block and B. Additional cost for machining for a 451 stroker. Not including assy.
I know I need to start calling more shops, only one I've spoken to so far is Dvorak and they are very pricy, but also have a good reputation.
