Bigal75
- 7:10 AM
- Aug 18, 2011
- Ottawa Ontario Canada
I had a 73 rr with a big block and it had rubber ones.
You are correct, pretty much doesn't over heat badly till going down the road. I will check the lower rad hose and make sure it has a spring in it. I'm pretty sure it doesn't. Hopefully going to install engine this weekend and give it the breakin for the new cam. I should be able to tell if she is going to overheat with ten minutes of running time at 2000 rpm's
