I rebuilt the Carbs last year in my 66 Hemi - these are original AFBs - using kits from Mikes Carburetors. Other than setting adjustments per specs I didn’t play around much with the accelerator pump operation. The car drives normally very well but I’ve noticed the few times I’ve eased off in first and then rolled into the throttle I get a big bog (not a backfire) and then the engine catches and I’m off. Finally looked at the accelerator pump on the primary carb and noticed I don’t get any thing out of the nozzles until almost half throttle. I pulled the carb, filled the bowl with some gas and played with the pump. Mikes instructions suggest a pump height of 1/2” with throttle closed. I have to stroke it down to 1/4” height before I feel resistance on the pump link and additional movement squirts gas. That just about buries the pump rod down in the casting.
Not the first one of these I’ve worked on but I must be doing something wrong.
Below I’m manually positioning the plunger where it starts to squirt.
Is it possible I have the wrong pump?
