Well, thank you all for your contributions! I guess there are as many answers as there are racers/engine builders
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
and we don't always agree on what is the best (iron/aluminum).
I will be using Stage V aluminum heads when the time comes to finish gathering parts, mostly because of the weight savings and quality.
Is there anything to gain by o-ringing the intake to head side, with the target hp for this engine (~600 hp). Tim Banning at FHO use that on all his heads if I understand correctly. He also uses some CNC machining on all of his heads and I must say they sound really nice, well except for the price.
Then there is Eddie at HemiHaines that quoted me a much more attractive price for a set of heads with standard machining such as bowl clean up, guide honing etc.
What is your thoughts on that? Go with the more machined heads (=better??) or go for the cheaper. It will most certainly determine when I will afford to finish the build.
I will also run with a solid roller cam and a, for a solid roller, mild cam to save the valve train (.600-.650 lift maximum).
What are your thoughts on oiling? I have a 7 qt oil pan now (I think) and I have read a lot of different thoughts about running a high volume oil pump and draining the pan. What can I do to avoid draining the pan if that really is a problem? Should I run a HV oil pump or a standard?
I will run oil-through-pushrod with this.
Thanks again for taking the time to help me with these thoughts and concerns.
Per
