Holley 4150 stud placement/size???
Keep an eye on your Lokar bracket... I've been using one that has the set screw also, and it still moved from time to time especially if I mashed the throttle. What I did to stop it was put a star washer under the carb-stud nut to bite down nto the bracket some and hold it better and that seems to have done the trick..it doesn't move now
Sounds good... right now it has a star nut and NO set screw, so I’ll be sure to keep the star on there.
Thanks everyone!
Switched out the 750dp for a 770 street avenger with vacuum secondaries. The relocated stud I described above, plus the new cable bracket, and appropriate adjusments to all involved.... She’s awake now. Sooooo much better to drive.
