john.thompson068
- 66 Satellite
- Full weight street machine
- 446ci 440
- Eddy RPM heads/intake
- Holley 850 double pumper with mechanical secondaries
- Comp 305H cam (.525/.525) 305 Duration (253 @.50) 110 lobe separation
- 1 7/8 headers 3" exhaust
- 10.5:1 forged pistons
- 13* timing
- 727
- 4000 rpm PTC convertor
- 3.91 gears
- 29" tall tires
Now that you have helped me set the timing, there is still two more drive ability issues which must be resolved asap. First and most important. Car can stall after turning, accelerating, then lifting at low speed. Like when pulling out of a gas station and immediately hitting a red light. Car can also begin to stall after turning and getting on gas harder but then needing to lift off because of traffic. The car comes out of its stall as long as traffic keeps moving so I can keep on the gas. These symptoms do not happen every single time these conditions are met, but happened one time each on a 5 mile outing today for example.
Second, car has low speed stumble when rolling on throttle from light throttle cruise speed. Stumble is even worse if throttle is rolled on faster. From light or no throttle to wide open throttle results in immediate rapid acceleration with no stumble.
