padam
I’ll probably get flamed for this, but I thought I remember reading in a direct connection engine book, that balancing wasn’t that important for a drag engine.
But I don’t care. RWHP line started to level at 4850. Grunt. Upshift.Been around BB Mopars for 45 years. Never seen one stop pulling at 4800. Maybe your valve springs have gone south.
Shorten the stroke, lighten the rotating assembly and solid cam w/heavy valve springs. 7500+ RPMWhat needs to change to make a big engine spin to much higher rpms, like 6500 or so. Not looking for a build recipe, although that would be nice. What needs to change in theory? Big blocks are known for low end torque. What does it take to make it spin much higher?
Exactly. About a 3.375, with a 4.31 bore. Max wedge heads.Shorten the stroke, lighten the rotating assembly and solid cam w/heavy valve springs. 7500+ RPM
When I suggested Ti valves that was for high end RPM for a motor seeing that level on a regular basis.
Were the slugs typical 850 gram TRW/Speed Pro pistons w/ 225 gram pins?With my old stock steel crank 440 with LY rods and forged flat-tops I'd shift at 7000 and at lower elevations and good air It would go 7200 thru the traps.
The pistons were custom forged Arias with .094 tapered wrist pins. I bought them in 1991 and don't remember the weights. They were virtually identical to the Custom Ross Pistons in my new 493.Were the slugs typical 850 gram TRW/Speed Pro pistons w/ 225 gram pins?
What cam, lifters n valve train are you using on the 440 ?I shift my basically stock 440 Sixpack other then camshaft at 6200-6400 ish. At 6500+ it flings one belt or another. I shift my 528 Hemi at 7600.
Yeah - my 574 is good good for 8000 rpm according to Tony Bischoff (won't know how high I will spin it till I get out of transmission purgatory). You betcha it has titanium valves.When I suggested Ti valves that was for high end RPM for a motor seeing that level on a regular basis.
Doug
