So if I understand you your 8 ga wire that runs from the battery in the trunk to the distribution block on the firewall does not have a fusible link? Although a stock car does not have a fusible link from battery to distribution block, I would put one in near the battery as protection in this circuit. Why? Well this wire goes a long distance through lots of turns and potential sharp edges. If it ever gets pinched, insulation wears off, etc, you will have a fusible link to protect you from a fire. Certainly not mandatory, but I would if it were my car.
You don't need a fusible link between the distribution block and the alternator. The stock alternator will work fine with 12 ga wire. If you upgrade your alternator, you should upgrade the wire but no fusible link is used in between - the alternator can't power 800 amps and weld metal...
As far as where to run the wire to the solenoid. Check out the picture below - I don't have a recent picture from my car so this is before it was restored. There is some incorrect wiring but this picture will serve its purpose. See the yellow and red wires on the distribution block? The wire just above that with the square basket to hold the wire is the mount for the starter solenoid.
![20111122_1031.jpg 20111122_1031.jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/190/190693-fb639a1fb70286a328eeec88df496e4a.jpg)
