You can design a cam to make exhaust manifolds better than they are with today's tech with roller cams and such. But I would ask the gurus here how they do it.
There's no magic. The same technology that has helped all hotrodders has also helped hot rodders using manifolds. Faster rate cams, better flowing heads, more cubic inches.
Honestly, nothing is new or changed, except until recently as some people have actually
tried to make more power with manifolds. Since the beginning of time, the
first thing hot rodders did was to put headers on the motor. Why? Because they make more power on everything.
The only thing that makes power is the intake. A good exhaust system (headers) helps the intake. A bad exhaust (manifolds) can hurt the intake. The only time the intake and exhaust are actually working together is when both valves are open at the same time. Not unlike any other motor, you need to find the sweet spot for when the intake and exhaust opening and closing events are. The cam event sweet spot for a manifold motor is just different than for a motor with headers. So you simply find ways to help the intake with little or no help from the exhaust. Obviously you will bump up against diminishing returns sooner without the exhaust helping the intake..
In 1969, Super Stock magazine, and I think Ronnie Sox at the wheel, drove a A12 car to 12.90s at 111 mph with crap tires. Everyone knows that the car was a bit of a ringer and speculated that it was at least super tuned on a chassis dyno. Maybe a valve grind, maybe a head mill. I don't know, I'm just speculating. But the point is
it went 12.90s @111 mph in 1969 with exhaust manifolds and a very crappy factory exhaust system.
Because some folks make a living in the hi performance world, including specing custom cam grinds, I don't normally share freely their intellectual property. But I'll say this, the factory cam went
12.90s @111 in 1969. Trust me, there is no rocket science here. The factory pretty much figured it out 50 years ago.
From my perspective, Bill getting that cast iron intake to go 11s @115mph with that compression ratio
is magic.
