ckessel
Can't go wrong adding grounds to the job and don't skimp on wire size used for them. The ground is the return path for the system. Bigger/more is better. As an example, look at a late model vehicle. Grounds everywhere for a reason. On the front lamp/tail lamp units for many vehicles, they use a steel socket that is swaged into the cast housing. That is a major area for no grounding after many years. See if you can get a tab onto the steel housing to attach a ground to if possible. Francis makes a lamp socket that screws together and may be able for retro fit into the old housing. Something to check into.
