theyre after market
I guess the biggest deal is that the shock mounts were never designed to be load carrying points-you risk bending or breaking the upper mount especially, as Monte Man illustrated. I have airshocks on Arty, came on it, there only because the leafs are shot. They are on the replacement list, as are the wheel hop prone Gabriels. Likely Koni adjustables going in, if I can afford them.
Still figuring out what I want to do. I'll let you know if I don't need 'em anymore. OK thanks.
Were the airshocks, with the inflation tubing a factory item, or do you think they were added aftermarket?
If you dont pump them up rock hard the shock crossmember isnt carrying the full load,you can get coil assist shock for these cars and it is no different then the air shocks.Its just another old wives tale sorta like unilug wheels.One person had a problem so everyone thinks there bad.
