- 4:49 AM
- Dec 4, 2009
- Pasadena, Texas
Well, a spark plug wire that has a higher resistance will decrease the strength of the spark. Higher voltage can help overcome wires with high resistance but IMO, the lower the resistance of a wire the better....and 'stock' carbon core wires always have a higher resistance than solid core wires. At least that is what I've observed over the years. Like I mentioned in a previous post, if you use solid core wires and experience radio static, use a carbon core distributor wire and change it out when it measures higher resistance than when it was new. Seems to me that solid core plug wires last for years! Mine did.....This may not be popular, but I'll say it anyway. Unless you are having miss fire issues, HP plug wires will not give any better performance than stock ones except for looks. If the engine is running well, you gain 0 HP by using 8mm and up wires.
Mark
