TRAMO
do you know which adjustment it is?There is another adjustment for that problem.
thanx big block. yea i just finished installing all the glass in my 70rr and had to do a lot of research to get them back together.the area you are talking about is a slot type bracket that the rear of the vent window frame sits in and the allen screw goes through the uppr door frame ( 1/4 inch hole) and through the first side of the door tab then the vent window frame tab then the 2nd door tab and then a nut that sits onthe 2nd door tab.the nut is strange looking ,its about an 1 1/2 inch wide and 1/2 inch tall. i thouht it just clamped on the vent window taband held it in place after the vent frame was set. you might be right i might loosen it and see if that helps. the 70 plymouth manual was not alot of help in re-assembling my car,since i did not take it apart,not sure about the jam nut. maybe some one will chime in on door glass and vent window adjustmentI'm going on memory alone here as my windows are out and I cant locate that particular adjuster. So if you will look at your door on the inside at the top there are 2 plugs.The one about an inch in diameter is for the mirror adjuster(it has the mirror adjuster or a plastic plug but not both DUH) and the little plug abut 1/4 inch diameter behind it. Pop the small plug out and there is an allen screw in there,it has a jamb nut of course. Loosen the jamb nut and turn the allen screw. It is probably rusted solid. And that adjuster may not have a thing in the world to do with your problem. But as memory serves that will solve your problem. Then again you may have something bent and cant adjust it out. Good luck and let me know how my memory is. LOL
sorry,it is two.that adjustment might be what im looking for. thank you resq302there are two nuts with studs on the front, upper part of the door jamb which moves the vent window inward and outward.
