I really appreciate all the advise and help, thank you guys.
I am still stuck though. I would like to know if anyone else has had this stalling when in gear issue. This was a sudden thing, happened when driving home from a cruise night at a traffic light it would just not idle in gear. dropped to below 300 rpm, I could brake rev it and then drive off to go home but this issue is driving me crazy and its been months. I know some have commented about my Idle RPMs but this car has run flawlessly with my set up for years so i do not see that as an issue. I will list below all that has been look at and timing and idle rpm that has worked for years. Please point me in the direction of possible fixes short of a teardown. its a 69 charger, its no show car, I love driving it just to have time to myself on the open road, it has been driven from Atlanta GA to Upstate NY several times without issue several time with current set up so I know that is not and issue but something has failed and i can be the only one that has had this happen.
440 .030 over, 484/284 cam, Edelbrock 750 performer carb, 727 with 2800 stall converter. timing 12 degree base all in at 36 degrees at 2800-3000 rpm
carter fuel pump. Idle in park is set at 1100 rpm and in gear at idle its between 850-900 rpm ( the car has been happy here for years and will keep the headlight lit bright at night with this rpm) this setup has never given me a problem
timing is still set correctly, cam only provides 11" vacuum at idle in park, only vacuum accessories are the headlight doors and vacuum advance on distributor. Fuel pressure is between 5 and 6 psi (needle on gauge is bouncing, since i just put in in to check the psi). no kinked or rotted fuel lines, fuel filter is new. I can not locate any vacuum leak, changed the base gasket on the carb with no change to the problem.
Only changes before the problem started, added new orange control box from Mancini racing and a new hotter accell coil for a hotter spark (i did change this back to the stock coil with no change to the problem)
I was a little low on trans fluid the day this happened but I am running a pan that holds two extra quarts of fluid so I know there was enough in the trans to work, it was topped off after the car got home, no change to issue (trans leaking from dipstick tube seal, have a new lockable tube that needs to be installed to solve the leaking issue), motor Idles now at 1000 in park and in gear it is extremely rough and at around 300 and it boarders on stalling.
I have someone coming over to do a compression check in the next week or so. I want to eliminate an engine issue, when running there is no signs of a problem thru the exhaust although it is a little richer than usual by the smell behind the car, changing the idle mixture has no effect on this at all.
I dont know if i wiped a cam lobe, but I need to try anything easy first. I am looking to purchase an eddy AVS2 carb at 800cfh if the carb is the issue.
Anyone with a similer problem please tell me what you did to solve it, i need to try simple options or the car will end up sitting, I'm afraid that if it sits past Feburary I will have to place it on stands and cover it for permanent storage.
