SgtLee511
This is the quilty answer i was looking to get. Thanks[/QUOTE]Best Suggestion you can get in this matter, is Check your Dash Vin to the Fender Tag, then go to the trunk open it and remove the weatherstriping on the lower part of the trunk and match up your numbers first. Thats some money $$$, then make sure you, your frame rails are solid be sure on that point, move onto the wheel wells and rockers. Its gonna be rusty, somewhere maybe around the window corners maybe not. Take your time, Check your metal prices for the panels and have a place to build it. Good Luck
Its all doable, building one now, its not cheap but if you can get it cheap your already saving money
