- 2:12 AM
- Dec 4, 2009
- Pasadena, Texas
I went the opposite way with mine....started by cutting off the pinch well flange and solid welding the K.....32 lbs now.
Hi all, what’s the best way to stiffen these k members up? Man mine on my 69 charger been through hell had to weld it up where it bolts to frame and motor mounts bolt loose.welded holes etc I’m thinking to weld it all up to make it stronger the factory welds looks like a beginner welded them. What do you think mopar group?
Tony
Did you weigh it once you were done with the reinforcement or did you not want to know how much it was once it was done?Later on here, I added in reinforcement pieces around the steering box mount. Also finally had the chance to trim off the excess material from the engine mount brackets. Partially just because and the other to gain more clearance for the oil line from the pump to the pan. Milodon external pickup road race pan. So, have your pick of ideas. There is plenty to do and is all up to you on how far you go, or how much time you spend.
