lights surging
Virg464
3:33 PM
Mid Michigan
Looking for possible idea to track down for an issue (maybe it's normal). 66 Coronet, not really a street car, rough idle, built/building the entire wiring harness for the car. Starts and runs fine, running lights, hi-low beam, gauges, elec cooling fans, elec fuel pump. Everything works, but when it's running and I let it idle (approx 950-1000 rpm), the lights surge (intensity), the fuel pump rpm surges (pressure stays constant 7 psi). Running a 60 amp OEM alt, using an OE style electronic voltage regulator, MSD 6AL ignition. Off idle that all goes away.
I know this is a very general/non specific question, so any thoughts are appreciated.
It could be the alt is on the threshold of charging, ie the alt output voltage needs to be higher than the bat voltage; alt voltage could be changing/varying slightly at this changeover point, which could explain why the problem goes away with more rpm which will increase alt output.
If this is the case, a slightly smaller alt pulley will likely fix the problem.
Put a voltmeter on it and make sure the how much the voltage is surging. It probably needs a regulator. The old point style regulator can be replaced with an electronic one that looks like the old one. Just make sure the case is grounded well to the firewall. A poorly grounded case will cause overcharging.
"using an OE style electronic voltage regulator"
In case you missed this.
Mike
