Now, keep in mind that THIS is the first time that I have ever taken on something this complicated. Up to now, I have never even replaced a frame rail....Heck, I've only gone so far as quarter skins, taillight panels and lower quarters. This is a major undertaking for me.
ElDubb440 gave me some good pointers, others have as well. He said that the sheet metal will dictate where everything finally rests. If the sheet metal lines up and has consistent gaps, the sub-structure is within spec.
Here we go......
I sprayed all mating surfaces with Copper weld through primer.
The K member keeps the rails in place and rigid. I made a bracket for the floor jack that sort of wraps around the K member to keep it from slipping off.
While the K member did keep everything secure, that proved to be a problem. The stock Charger sheet metal bracing was left in place and as a result, the rails could not flex to squeeze in between both sides. The rails spread apart from the firewall to the torsion bar crossmember so its as if they have to come straight up from underneath IF they are left rigid. If I had removed the little side braces, this would have been a bit easier.
I was out there doing this alone so I had to find a way to do it myself. I just removed the K member and used jack stands under the front and rear of the frame rails. With the K member out, there was enough flex to get it all in position.
