- 6:52 AM
- Apr 13, 2012
- Granite Bay CA
Great...I am considering the SST 5 speed for my red Charger.
thats cool its kinda like a beautiful woman with no make up partially dressed, leaves more to the imagination.No, I'm actually going to leave it ratty while I work to get it running. I'll probably drive it around this way until I get ready to paint it. I am likely to retire and leave this state within a year or so. I want to have it driveable for the move. It costs less to transport a car that runs and drives.
According to the Summit calculator, I'd be at 7.85 to 1 with the .039 Fel Pro gaskets.
How the heck did they come up with 10 to 1 ratings for the 383 Magnum ? They used the same heads. Even with a zero deck height, the numbers don't come up to that.
Another site:
Bore: (diameter) 4.25
Stroke: 3.38
Cylinder Head Volume: 88cc
Effective Dome Volume:
Use (-) for Dome and (+) for Dish.
Deck Clearance: .076
Compressed Gasket Thickness: .020
Number of Cylinders: 8
Compression Ratio : 8.44 : 1
This is with the factory .020 gasket.
Taking it to a ZERO deck puts the engine at 9.48, still half a point below the factory rating. Has anyone here seen a 383 with a zero deck height piston?
This is disappointing. 7.85 compression ???
I have a 440 from a '71 Chrysler 300, dated November 1969. I'm tempted to pull a head from that one and check the deck height.
This 440 ran decent when I pulled it over 11 years ago.
It looks to have had regular oil changes.
View attachment 948093 View attachment 948094
I couldn't get it to spin over though. This cheap *** engine stand looked to be ready to fall over every time I cranked the long breaker bar on the crank bolt. I pulled the plugs and sprayed Liquid Wrench inside. A couple of plugs were missing.
Guess what ?? I pulled the left head and it looked pretty good. THEN I pulled the right side....
Here is a closer look:
What the heck is that ? The cylinder has surface rust and some crud that is hard to remove. This engine was also looked at to be a rering job. Crap like this surely means that the rust is probably deep into the bore enough to warrant more than a dingle ball hone.
Since it looks like new pistons for either engine, I looked to the last big block I have.... The second 440 that I built way back in 2004.
This one snapped a rod at 846 miles. I pulled the engine thinking that I damaged the block and just bought another 440 core to build for the red car. Since then, I've found that this engine can be brought back with a new piston and a good rod. The crank wasn't damaged. The big end of the broken rod is still attached to it.
Ahhh.... The classic Speed Pro 440-Six Pack pistons! Yes! With a .025 below deck height and 7 cc valve reliefs, it will yield a 9.26 compression ratio with stock uncut 906 or 452 heads. I can have this dude back together far cheaper than by boring the other engines and buying new pistons. I could mill the heads .050, deck the block .010 and have it near 9.8 to 1 for a few bucks...
Still mulling it over though.
As usual, I go back and forth with several ideas before making a decision.
If it is a given that most 906 and 452 heads are in the 88 cc range, the math shows that taking .050 from the heads and .010 from the block deck raises compression by about a point. If I were to use a stock type .020 steel head gasket, this stock piston 383 would then calculate to 9.02 to 1.
Stroke: 3.38
Cylinder Head Volume: 78 ccs
Effective Dome Volume: 0
Deck Clearance: .066
Compression Ratio : 9.02 : 1
Total Displacement (in.3) : 383.6
That looks like a great idea. I'd also take a measurement with whatever thickness of gasket you're going to use.Cylinder heads....
I'm going back and forth on which engine to use but either one will end up with the same style of iron heads. I have 2 pair of 906s, a pair of '346s and 2 pair of '452s.
I pulled out the '346s to get a look at them. They look too clean to be totally original. The chambers are clean, the valve stem seals are the Viton style and it looked like the chambers were smaller. I've never checked volume on a cylinder but I've got a pretty good idea of how it is done. I've surfed around online and read about milling and reducing chamber volume. I've even read of a few that have milled the open chamber heads far enough to make them closed chamber. I have no intention of going that far but it made me curious. I wondered how much you'd have to mill to get to that point so I did this:
Totally UNscientific and ripe for errors BUT close enough to use as a comparison against other heads. I used a simple Carpenters square and feeler gauges to see how deep the open chamber is.
The '346s were the shallowest. .077 deep. A pair of '452s in the shed were .101.
This was on one of the 906s:
Another 906 from another engine:
Every pair of heads showed a different number. The .101 number could be virgin, uncut heads. The '346s could have been milled .035 or thereabouts. I had considered milling uncut heads down to 78 ccs anyway. I may already be halfway there.
