- 5:42 AM
- Apr 13, 2012
- Granite Bay CA
All the header bolts were coated with thread sealant since on stock iron heads, the threads go into the coolant passages.
Next up was the cross shaft for the shifter. For now, I am keeping the column shifter in place. I was putting this together with the parts that I pulled from Ginger and some of what came with this car.
First off, the cross shaft wanted to sit out of level. The transmission side was the high side.
(Forgive the next 2 pictures...They depict the correct setup that I stumbled onto. I did not take pictures of the first incorrect arrangement.)
I thought that maybe my suspicions about the transmission mount being too tall were showing another symptom.
What I needed to do was to drop the end that attached to the transmission so that it sat level. This makes the levers work properly because they would be swinging in the proper plane.
This bracket......
Comes in different heights/offsets. I first had the bracket on the right, then I tried the one on the left. It made the difference.
What I needed was the shorter bracket to lower the transmission side.
This bracket......
