I curve distributors on my machine with a secondary system built on, for many different combo's. Decent results so take this for what it's worth.
Question
why would it ever hurt, to run vac advance?
Answers
- on a more radical build, the mechanical advance curve may not respond well to more advance at cruising speed. A surge at cruise is a common result.
-On a 4 gear car that is driven hard, the resulting vacuum applied on the shifts, throws an unwanted variable into the mix.
Q Why would you simply not bother with vacuum advance?
-vacuum advance's purpose, is to make the lean cruise mixture burn more completely, giving better economy.
On cams with say 235 @ 50 duration or more, it simply doesn't help. That much cam makes the economy poor, and adding the vac advance makes no measurable difference.
- Some feel that there are performance benefits to running vacuum advance. The truth is, if your car runs or performs better with the vacuum advance hooked up, there is something wrong with the set up. Vac advance is for economy. That said, I do understand that fuel is expensive, and these cars use a lot of it, so trying to get some more with vac advance makes sense for most mild street builds.
Running manifold vacuum over ported
-It was only done by the factorys in the late 70's. By then the things going on with way the cars ran, and what they were trying to get emmisions wise from carburetad vehicles made it necessary. Makes no sense on one of these, tuned for performance (and even economy) and not emmisions
Why shouldn't you run manifold vacuum?
-I know Don at FBO, and learned many things from him directly in the area of distributor curving. That all said, I have no idea why he recommends guys run manifold vacuum.
By Don's own school of thinking, we curve the distributor to run the MOST initial timing possible, and keep the total mechanical around 34. It improves throttle response and idle quality DRAMATICALLY to do so. SO after doing that, I don't see how adding even more timing at idle is the right thing to do. Using ported, ads it only at light cruise, and THAT is what vacuum advance is for. To improve economy at light cruise. To give the lean cruise mixture, more time to burn.
Don is VERY knowledgeable, and does a great job on his distributors, BUT most of the ones he curves are for more radical builds, and he is a big supporter of not using vac advance at all.
Ported will always do what vac advance was designed for, while I don't see how manifold will
