Wietse
I just did my front suspension as well and run against the same issue as OP did.
They were installed anyway as i had nothing else for now to replace them with.
It did need a hydraulic press to get the pivot shaft in, after walking about and getting ready to press it in the LCA the pivot shaft just fell out...
Imagined after pressing it in the LCA it would end up tight maybe but it did not.
Other side was exactly the same story.
Did notice the old bushings were also very easy to remove, the shaft did not appear to be worn, this also should have left a small lip on it if it was worn.
Tightened them using a vice grip, after setting the ride height and the weight on the suspension i did the last tightening without the need of a vice grip as it would no longer turn when tightening the nut.
I used the same bushings as mentioned before, MOOG MK791.
