Why not eliminate factory gas gauge and temp gauge too?
If it's less information you want then go the whole way.
Don't worry, you'll still know when the car has overheated and when you run out of gasoline.
The gauges just cause trouble, so do away with them.
I don't yet comprehend how so many people would willingly give up knowing charge/discharge information, then show up in a tech forum later asking about low charging effectiveness.
The problem is not having an ammeter, the problem is way the stators are wound now on alternators, with too few turns in each pole section, resulting in low output at idle speed.
Get a stator wound as the factory original was with at least 12 turns per loop, and everything will work as designed.
Why couldn't crappy alternator rebuilding for the last 35 years plague GM or Ford vehicles...why are their stators wound to factory specs and Mopars get stuck with low output @ low rpm....the higher amps they advertise, the only thing they do is wind the stator out of heavier wire, but then they can't fit as many turns in each loop, and the idle output suffers greatly.
But I actually believe this was a conscious decision by rebuilders to handicap Mopar vehicles, made sometime around 1977.
