64savoyguy
Ok guys. I got my engine put together and ran on the dyno. It made decent numbers. 520hp and 530 ftlbs torque at 4400. I have a comp roller thumper cam and all the necessary valve train components per comp and my engine builder ( who I would recommend to anyone building a mopar or any engine). Got the engine in the car and put about 170 miles on it. Rev limiter set at 6000 rpm and it's seen that twice. I go to start it two days ago and it fired rite up, ran for about 30 seconds and then started knocking. if u give it a little bit of gas it comes out of it. (Around 1200 rpm). But at a n idle it sounds horrible. I don't think it's anything in the bottom end but what do I know. Long story short I'm wondering if any of you have ever had problems with bad lifters causing this problem and what you did to remedy the issue. I like everyone else have heard good and bad about comp parts. Thanks in advance for any ideas.
