I have bought a max wedge scoop from one of the manufacturers, It was pretty decent, Based on it, I recommended to a the same company for their hood and scoop for a 64 Dodge. when I saw the car the next summer I was pretty disappointed in what I saw. The hood was over an inch too short. In order to line up across the front with the fenders, There was a gap across the back large enough to put your hands down. I could almost see the cowl gasket. I was shocked. I asked why he would even put the hood on the car. He said I have enough money into it now I have to use it. However I took the plunge anyway and bought a Hemi Scoop for my car figuring that the hood issue must have been a one off mistake. The scoop was horribly packed by the maker and was damaged in 3 corners. The mounting studs had been bent and couldn't be straightened. With very little force they snapped off. Certainly not strong enough to hold at any serious speed. Also, What ever coating was put on the scoop reacted with every type of primer/sealer my body guy put on. It was sanded and redone 4 times and still isn't perfect. We ended up having to remove the remaining studs and use panel glue to hold in Rivnuts. They are great and solid. We left the one stud at the front. There are probably close to 25 hours in it because of the issues. My advice is to buy the best scoop you can afford and be prepared to have to do major work on any one you get. I'm not naming names because I never contacted the company but if you want to PM me Preacher I can give you more info.
