moparcrazy
Got my Mega Block Today wondering how much Horsepower could this thing take 1500HP ?? my goal is 1000HP
Mine makes around 900. Never had an issue. I'm going to swap in some new springs and check bearings after Christmas. Current has 185 passes since freshened. My bet is it'll go at least 400 with springs and maybe bearings. Even the lifters are looking good. Building an honest 1000hp on motor is going to be tough unless it's got Predator or Hemi heads. Doing one that is low maintenance, good luck. Now 1500 with a turbo, piece of cake, but not cheap. I'd bet 25K in parts. That being said 850 is more than will hook up anywhere on the street. It'll black track from a 50mph roll.I know they can handle 1000 horse, not sure of limitation. I think @dvw has one. Did you get the one I looked at?
Hello DVW wondering if you wouldn't mind sharing about your build & what heads are you running Thank you, Jay.Mine makes around 900. Never had an issue. I'm going to swap in some new springs and check bearings after Christmas. Current has 185 passes since freshened. My bet is it'll go at least 400 with springs and maybe bearings. Even the lifters are looking good. Building an honest 1000hp on motor is going to be tough unless it's got Predator or Hemi heads. Doing one that is low maintenance, good luck. Now 1500 with a turbo, piece of cake, but not cheap. I'd bet 25K in parts. That being said 850 is more than will hook up anywhere on the street. It'll black track from a 50mph roll.
Doug
WOW DVW that's a great looking Engine !! looks deceiving, have you heard anything on the 572-13 Indy heads ? and are they capable of big power like 1000 plus HPView attachment 550195
572", MCH ported Indy -1, 440-25 crossram, 2 Eddy 750's, diamond flat top 15-1, .9,.9,3.0mm Total Seal, Molnar 7.100" rods, Mopar 4.500" crank, Comp 285/[email protected]", Isky red zones, Jessel belt, T&D paired 1.7 rockers, Trend 7/16x.165" tapered pushrods, Charlies pan, GZ vacuum pump, Hooker 2 1/8", MSD crank trigger. Been a solid combo home built from used parts. I've put nearly 500 passes on it. Been 9.04@149 3345lb 64 Plymouth on 10.5 tires.
Doug
550195[/ATTACH]
