440ronnie67
Hardest thing, most stressful thing. Working around fresh paint.
I apologize if you already stated, but what are those black mounting clamps/blocks used for the stainless lines? Particularly the one below the relays and the ones in the most recent pic.
Amazing work as always, Pat! Apologies if I missed it but could you show how you routed your forward wiring loom under the fender?
Thanks Pat. What about that mounting block that the stainless line clamps are fastened to?
Pat, you are kinda blowing my mind here.
I went back through the thread and forgot you filled in the hole for the electrical bulkhead connector.
When you have a chance would you mind grabbing a pic of where you have the bulkhead connector mounted?
Thanks!
Thanks!
Here are some pictures of the bracket I made to hold the bulkhead wiring harness. The bracket is only a few inches away from where it would have passed through the firewall. The other half of the harness is connected to the dash and I have yet to install it. Hope that helps.
Pat What a Awesome Charger Your Work is the Best! I have never written anything on a forum before so I'm not sure if I'm doing this right! I have a 69 Charger RT and I'm doing the mini tubs and RMS suspension I'm going to stay wit 15 inch wheels and I was wondering if you could tell me the specs of your wheels width, offset and so on Would really appreciate it! Thank You and a again Awesome Charger one of a Kind!With the battery being relocated to the trunk and needing a few direct to battery power connections I made a breaker/switchbox to be located in the trunk. The 12”x 9” box holds a remote battery disconnect and starter solenoid. It also has a series of breakers for the alternator line, dash power, subwoofer, fuel pump, fuel injection, and a few other low amperage items. I still have a few details to work out, then disassemble the box and paint it black along with labels for the breakers before I install it.
Pat
View attachment 897266multi photo hosting
