Modern Bullitt build
I installed the fuel tank so I could mark the trunk accessfor the fuel pump and sending unit. The tank has a EFI pump inside and addingthe trunk access will make it easy check or remove without dropping the tank.
Thanks
Pat
on cutting out your acess hole did you just hammer out the bead stiffners flat?
In the film, the bad guy in the Charger sweats a bit, then with golved hands...puts on his lap belts. No good. He still dead. Lap belt confined him to burning wreck Good!
DO NOT emulate him!
Install shoulder belt mountings while the car is apart. Best are simple, tight, but retractor MUCH safer than just seat belts. I just put back seat belts in my 63 Sport Fury vert, and will find modern seats with integral shoulder belts...so I can drive fast with confidence! GW McCarthy MD biomechanics expert...a little.
Next Mopar project is a 1958 Plymouth Fury go kart;-) 66 year old Powercar used as a dealer promotion
Getting close to owning my next project;-) 45,000 original miles, original paint, original family 69 roadrunner. Off the roads sometime in the mid to late 70s. It was started back up for a week or two and on the roads in the late 80s and then sat in a garage ever since. I’ve known about the car for close to 20 years and got a chance to see it for the first time in person today. Incredible documentation, lots of early 70s pictures and registration throughout the years. Fingers crossed everything comes together, and if so, I will start a preservation thread.
Thanks
Pat
Where does the positive battery cable pass through the floor ??
I used Matt black vinyl to cover the silver insulation (recommended by others) then started to install the new headliner. This is the fourth car I install the headliner on, and it seems to be getting a little easier ;-)
View attachment 838635make image url online
Hey Iv been enjoying your build and looking it over as I’m doing my build I was curious if you know where to get these clips. Thanks
Hey Pat, where did you source that utility box you're using for all the electrical in th trunk ??
What is the item circled in yellow? BTW, I managed to find that box on Amazon also.
Thanks
