69 Coronet R/T 440 N96 equipped, P/S, HD cooling, 3 speed wipers (mandatory with N96), Y2 Sunfire Yellow, and they left the brake backing plate in place when the car was painted (manual brakes)
eh-hem...(clearing throat)
Rolling Thunder is correct...but he failed to say why a 66 Charger?
Answers are as follows:
Car make, model, & year is 1966 Dodge Charger, why? Because of the hood release cable from firewall up to front of grille...66 Charger was the only one that had this. 67 Charger release was under the hood chrome. No other 66 Mopars had inside hood release.
383 4-bbl engine, why? Note 4bbl carb under the unsilenced air cleaner...361 engines had the large air cleaner and 4bbl was not offered. All 383's in the Chargers had only the 4bbl carb in 66 and the little air cleaner was standard.
Not 3 speed wipers, only variable speed was offered in 66 on the Charger, in 67, 2 speed was standard and variable speed was optional. Starting in 68 they offered a 3 speed wiper motor (which I heard is the same as the earlier variable speed)
Yes, power steering, no power brakes, and yes, 4spd car...clutch linkage showing through firewall and also you can see the 2 pink wires across the firewall down to the trans light switch.
So, only the hood release cable would have told you the year and make of car, only the air cleaner would have told you the engine, and the clutch linkage and reverse wires would have told you the trans.
Thanks for playing...car is a 160,000 mile original Charger, except for the new interior and the electronic ignition)
(PS: had you guys been sneakier, you could have seen this car at my Hub Garage..link is below)
Tell me what you can
oh ****.....
