Well fellas I feel like I've finally zeroed in on my setup to where everything is in harmony or at least until this issue popped up.
I just wanted to pick your brain on fuel delivery mostly the pump. I have an issue, I'm running out of fuel during full throttle runs where I'm hammering down for long durations. Yesterday I put a fuel pressure gauge in the window in hopes of getting it to repeat but no luck but during a long full throttle pull I did get the fuel pressure to drop from 5.5 to under 2 so even though I didn't get it to repeat the issue I feel there's definitely an issue with pressure. I'm running a QF 750 so it shouldn't require a ton of fuel and am running a 3/8" sending unit, line and a Holley mech fuel pump. I don't want an electronic pump so are thete any other good options that have threaded ports and not just barbs? I'll be checking fuel lines and hoses before I purchase a new pump.
