Yes, I think I got mine from Jegs or Summit
I really, really don't want an electric pump so this is good to know. Just like the simplicity of 2 bolts and 2 lines... Done.Mine ran fine on the dyno with 590HP. I used the 5.5-6 psi one.
Just bought one from Summit, $73.97.
No canister on mine, just a pump. What exactly are they for? I've always just ran one line and got a pump that didn't require a regulator but have heard a return line helps with vapor locking?Yeah 747, so if I have a fuel issue now I know it's behind the fuel pump. I've also heard that some of the new vapor canisters have to big a orifice for the return to tank and could do the same thing.....but that is just rumor I can't prove it one way or another.
The edelbrock pump is 3/8.So you can buy the 3/8"? I'll have to do some looking.
Hoping to have it licked this weekend so I can get back to hammering on it.Hi Devin, I have been running an Areomotive Phantom 340 in tank fuel system on my QF 950 with awesome results. You do need a regulator also. Allot of big block guys with big fuel suckers go this route to keep a stock look. Good luck, hope you get her fixed soon.
https://www.summitracing.com/parts/aei-18688/overview/
One of the first things I'm checking before buying a pump is that hose, the only rubber hose in my setup is the one on the tank that's about 3" long. Good to know they make a hose for it. Wonder if there's enough nipple on the sender for a compression fitting so I can convert it to AN fittings and braided hose??Don't know if it's been mentioned, but any rubber hose used makes a difference. Been told today's gas eats at the rubber. Gates makes a rubber fuel hose that holds up to it. Sorry, don't have the #, but parts house should know.
