451Coronet
Lots of smoke, coolant spraying, and burning smells!!!
Okay so fired up the 451 just now....I checked and rechecked coolant levels, oil pressure, connections, ground, fuel in carb etc
Lil info before hand:
400 w/ steel crank short block prepped by Kammer&Kammer
running 9.5:1 give or take a couple tenths compression
Eddy performer fuel pump
Eddy Performer RPM hyd cam
New Crane pushrods and lifters as well as adjustment rockers
Eddy 1406 electric choke (just for break in)
Aluminum rad
Flow kooler water pump
running 93 octane fuel
fresh dizzy (electronic)
Fresh batt
fresh starter
Fresh alt (duel field, w/ conversion harness from year one and flat pack regulator)
It fired right up w/ a lil starting fluid, took it to 2000-3000rpm (wasn't positive, tach wasn't working) but oil pressure was good and ran good with a slight shimmer, but overall fairly smooth. Sounded AWESOME!!!
About 8 min into running, it dies, no sputter, just dies.....smoke pours from reg and from what seems plugs and wires!!
Doesn't restart and the green wire coming off the 4 prong ballast resistor is ASHES!!!
So im obviously not getting spark now but when I crank it over.....im hearing a pretty audible knock!!!
What gives!!!!
Any help advice criticisms you bunch can offer would be greatly appreciated.
I just wanna know what happened before I try this again.....if I even can, that knock has me worried!!!
Aluminum rad
Fresh batt
fresh starter
What gives!!!!
