Ok I had some ignition troubles late last summer so I bought an MSD ready to run. I put it in and could not get car to run well at all. Double checked firing order what seemed like 100 times. Called MSD tech support was told I had a ground issue so ground direct to battery still pop, backfire. Tech said bypass ballast resister. I have 12 volts at coil positive. Sent distributor in to be tested while I waited I fixed my other distributor. When I got MSD back there was a note no issues found but instructions for bypassing the resistor were highlighted. I put the car away for the winter and forgot about it till last week. So today I thought let’s try again. Same **** different year. Backfires, timing bounces around, hook up vacuum advance and it dies. Needless to say I am not too impressed with MSD. When I bought this I went all in wires, coil, and distributor. I am really disappointed with this product.
Is anyone else have issues with these?
