Gary P
- 10:10 PM
- Aug 21, 2019
- Pleasant Grove, Utah
So far today....
I left the cable pretty much full length until I had finished sorting out the adjustments and I would rather have the excess cables at the throttle than be short on length. It is really up to you how tidy it looks. For me it has to function and be adjustable for any future updates. You can see there’s lots of cable past the end connector.@64fury74charger thanks for that mate that's awesome ^^^
I actually don't have any more cable left on the kickdown, so I have to release some from the trans end. Did you have to cut your braid down a little? I've not cut the kickdown cable at all and it seems a bit short.
Add this to the list of frustrating things that happen to car guys:
You make a change that makes no sense but it fixes the problem.
Sounds like you’re close, maybe try to set the cable up so when you get wide open throttle the transmission arm is almost all the way to the rear of the transmission. My understanding is this is the correct way to set this up. This refers back to having the cables pull equal distance when the throttle moves. Hope this makes sense.
