Those springs will work with the Lunati and Crane I listed. The Comp is a fast-acting lobe with .525" lift and may be pushing it. Although the Crane is a .504/.528", it is a slower rate of lift and I have personally run it with those exact springe with no issues. My GO-TO cam for a street 383/400B is the Comp 275DEH which would also work in your application (tons of bottom end), and is only .462/.482" lift. It also works well with exhaust manifolds and closed exhaust. On a 400 with HP exhaust manifolds and a DP4B in a Challenger with 3.23 gears and a 2400 factory 11" converter, it was a screamer on both ends, I'd say 2500-6000+ powerband. Your 440 would peak sooner, like maybe 2000-5500 band, perfect! #21-406-4 still available direct from Comp, it was pulled from the catalog to make room for Xtreme and Thumpr grinds they were trying to push. They work great! I have used the 255DEH in a 318 truck and a 265DEH in a 360, which was a beast. The Comp drop in springs (#901 SB and #911 BB) accomodate these cams, as will your Street Hemi springs.
