69superbee383
I do actually seems like a good idea to meSounds like a 484 cam to me. Do you have a 750dp to try to see if your seat of the pants likes that better?
To this point I’ve often wondered how throttle body fuel injection would work specifically with some of these cams that have throttle response issues at low rpm.I do actually seems like a good idea to me
sounds like you should back off a touch.
Also sounds like you've saved yourself a lot of effort in no longer needing a cam swap!
Cooper cobras. I will say I had bfg t/as years ago and they without question spun way easier.What tires? I can tell you that the difference with BF Goodrich rocks vs the Atturo az800's both 275's is huge in spin vs grip.
O the bee is no virgin to some clutch dumping action I have the broken ears on the block to prove it. My goal isn’t really spinning tires but I am using it as a measure of low end torque. I feel like my combo should have enough low end torque to light em up with a stab of the throttle at low speeds without having to dump the clutch.When you're at these super low rpms and can't get the tires to rotate, try pushing the clutch pedal in, then depressing the accelerator to the floor, and quickly release the clutch pedal.
Good grief. Post #9.O the bee is no virgin to some clutch dumping action I have the broken ears on the block to prove it. My goal isn’t really spinning tires but I am using it as a measure of low end torque. I feel like my combo should have enough low end torque to light em up with a stab of the throttle at low speeds without having to dump the clutch.
Finally decided to bite the bullet and order this cam and looks like it’s on back order. Back to the drawing board.If track ET’s aren’t a factor in the cam choice, and you’re looking for a responsive, very drivable street cam.......and a solid isn’t in the cards...... I’d suggest the Crower 271HDP.
