My 70 SE 500 Charger Rebuild
Engine mock up…
The engine looks great.
Be aware that it will not clear a stock hood. I don't recall if you have an aftermarket scoop or not but the RB block in a Charger with even an Edelbrock RPM intake and 4 barrel requires a deep drop base air cleaner.
Single plane intakes like your Torker 2 and the Victor do sit at least 3/4" taller.
I'm not trying to piss on your efforts, I just thought I'd let you know.
Thank you for your comments…. I’m covered!
Update: finish off trunk area. Installed rear window. Completed engine bay wiring for electric fans, Aces Kill Shot fuel injection computer and new Engine sensors for Fuel Pressure, Engine temperature and tachometer output.
Finally was able to get the stripe installed on the car. It Took me two tries. 1 to 10 I think it’s about an 8.
Installed the windshield today. One more thing off my to do list. Getting closer to first drive day!!
Major work was completed in last 72 Hours. The engine and transmission are in…. Transmission rolled of the jack once today, but no damage. Everything fit, but very Tight clearances…. But I got it done!!
