Hey there fellas, a couple of updates...
In keeping with my budget build motif, I decided to go with a 440 source aluminum water pump housing (already had the Source aluminum pump, now it has a friend). Should arrive in a few days.
Also, I've been looking for some quality bolts and I think I found some. didn't want to go full ARP ($$$) but really didn't want the gold zinc grade 8 look (and forget my oem bolts). So I found some 12 point flange bolts that are "better than grade 8". The black 12 points should really pop against the orange motor and at way less than $1.00 per bolt for most of the bolts, undeniable VALUE. I bought a bunch extra for other projects, but I'd estimate bolts and washers add up to $50 or so for all the exterior bolts (water pump housing, intake, valve covers, timing cover, valley pan, distributor hold down, fuel pump, thermostat housing and headers plus misc ground points, etc.)
http://www.allensfasteners.com/search_results.asp?txtsearchParamCat=74
Also picked up a firecore distributor. I planned on going with an MSD pro billet, but went with the firecore simply because of the vacuum advance. I'm surprised the MSD didn't have that option for the low deck.
I hear ya on that. One day I'll be in the market for an OD, that's gotta be sweet having all that low end torque and still cruising at 2000 rpm or lower. Me, with my 4.10's my cruise rpm is 3000 lol. But I'm building the car as I would have when I was a kid. I could see a gear change or even OD in the somewhat distant future.
