I started installing the front floor pan. I ordered it from Jeff @ 521 Restorations. He’s a great person! Despite getting two separate phone call from the shipping company telling me I would receive a call one hour before delivery (the first person that called me said) and a call 1/2 hour before delivery (the second person said), no call
This is what I found when I got home from work:
Don’t mind the different color/style pavers. They’re temporary until I can get the driveway redone.
There was only a small bit of damage to the pan that I was able to hammer out (most of):
Jeff was great. He was able to get me some $ back from AMD (they shipped it directly).
After test fitting, I traced around the framerails, crossmember, inner-rocker, etc. I then placed my old floor over the new to mark out, roughly, where the original spotwelds were. I then drilled them out:
I only had to trim a small amount off the bottom corner of the passenger’s side and the top corner of the driver’s side.
The crossmember hump was a BITCH! I’m not sure if the pan got bent or something in shipping but the pan was siting a good 1/4 inch away from the crossmember at the hump. After bending the pan a few times, hitting it with a BFH and some strategically placed torx screws, I was able to pull the pan flat against the crossmember. It fought me the whole way. I was able to spot weld in half off the pan before running out of time:
And of course, my drill decided to self-destruct in the middle of it all. I had to run out to Lowes for a replacement. I can’t complain, I’ve had it for about 10 yrs and put it through some abuse.
