AngryPossum
- 10:32 AM
- Apr 6, 2023
- Stryper Bass Island NY
I just got a transmission leak repaired on my truck, it had a bad torque converter seal and possibly a transmission pump seal, that was leaking heavily. The leak happened while I was pulling my boat a few weeks ago in 90 degree heat.
So the mechanic replaced all the necessary seals, o rings, gaskets, etc and purposely overfilled the transmission fluid, so far the leak is fixed. PS The transmission was removed when doing these repairs.
Question, is this normal to overfill the transmission fluid after doing this repair? The fluid was way overfilled when I got home with my truck, he said to drive it at least 80 miles and check it. So I asked a few mechanics afterwards and they said that's not normal. Your thoughts.
