bigowhiteboy
Okay, so I picked up a 75 truck block 440 the other day. Pulled valve covers and identified the heads as 346 casting.
I am wanting to build this 440 to go in my 66 Belvedere wagon which is currently a 318 Poly. It will stay a column shift automatic.
I would like the 440 to be a well mannered street engine with roughly 400 hp, really would love alot of torque.
I also have a chance to pick up a set of 68 440 heads that just came from the machine shop for $500. Would it be better to have my 346 heads worked over, or would the 68 heads be a better performing set of heads. This is going to be a budget build, so aluminum heads are not an option right now.
Looking for an advice at all on what combos have worked for anyone else.
Not wanting compression to be over 10:1 must be able to run on pump gas
