bth0320
Hi folks,
For those that use these rockers, I am hoping you can assist. This may be a dumb question but the instructions (and the pictures) are not real clear regarding the use of spacers and shims. I am installing these on Edelbrock performer rpm aluminum heads and some of the pushrods are hitting the side of their respective slot in the bottom of the head. Should I be using those thicker "C" looking spacers with this type of head or the shims that look like thin washers....or does it matter which I use as long as I get the pushrod in the correct position? Should I be using one or the other regardless if the pushrods are hitting? Originally I put the rockers on without the use of either the spacer or the shims. The instructions seem to contradict themselves when using aluminum heads and I have no idea what they mean by protrusions in the rocker stands....
As always, thanks for your help!
Brian
Brian
