Also need valve gear assembly lube spray from comp. I hit the locks with a few sprays and a soft tap with a dead blow then use the tool and the spray when reassembling. So easy lve literally had my 9 year old son do it with me
I have a KD 2400 that I used 35 years ago. Works great, pull the rocker shaft off, use a blank shaft, pull the spark plug, push cloths line into the chamber, change spring. I've done that several times during races. Changed spring between rounds and won the race.
Eastwood Universal spring compressor 2078? I used one to change springs but to make it easier I put a hose clamp around arms that grab spring to keep them from slipping off spring. You can weld/braze a nut on the part you use to tighten it then you can put a socket on it. I had piston at TDC on each cylinder as I did them plus compressed air.
