Backpacker
- 6:36 PM
- May 17, 2019
- Arlington Heights, Illinois
Hi guys! So I am starting to restore my 70 Roadrunner (4spd) after many years of storage. The NOM worn out cast crank 383 (yes, cast) that hasn't run in years needs to be replaced with a 440. Don't care about originality but it needs to look somewhat "right". That being said, I am starting completely from scratch with a professional engine builder. The plan is to use the HP manifolds with an H-pipe, run on pump gas, and increase the HP/torque as best as possible while maintaining streetability.
Should I rebuild a pre-73 forged crank 440 with ported 906 heads, get hardened valve seats, and call it a day? Or, rebuild a 73-78 cast crank 440 with ported 452 heads, and have it stroked? Cost wise between the two, it isn't that much different...
Will the HP manifolds kill off any gains made by the increased stroke and porting?
Should I use a painted (single or dual plane) aftermarket intake or just use the later cast iron TQ intake and have the center cut out (like I saw some members have done in a previous post)?
How much more lift/duration (if any) should be added to the cam (keeping the steel rockers) to match these changes without going crazy?
