Im at .101 primary and .110 sec.
Ya was at factory yesterday and same thing. Still wanting more fuel WOT. I'm OK to make the change. With low vacuum, I doubt I can get this tuned right.Maybe change carb jets and rods back to factory, that it was calibrated to have correct AFR at sea level and work your way down, according to elevation. There is probably a recommendation in the book. It's not about getting alot of fuel, but the correct mixture of air and gas into the engine. Extreme changes rarely work. It would be easier with a dual plane intake manifold.
No no. That's when I mash the pedal. Initial at idle is around 13.6-14.1. Light throttle and cruising around 12.8- 13.2The initial 18 AFR is probably the accelerator pump not delivering a big enough shot. See what squirter you have and step up to a bigger one. If the rod isn’t on the inside hole nearest the pump you can move it to that to get a bigger shot, but it will be of less duration and that’s why a bigger shooter is a better approach.
K..just checked again after moving to fartherest hole on pump. No stumble now.No no. That's when I mash the pedal. Initial at idle is around 13.6-14.1. Light throttle and cruising around 12.8- 13.2
Yes...KD works. I was wrong. They're 906 heads and yes we're ported some and large valves.is the transmission kicking down to a lower gear at wot ? were the heads ported for the 2.14 1.81 valves in the 516 heads ? heads could be a big problem if not done right even done right with the bigger valves and porting it has to hurt torque. the 800 AVS2 won't be causing you these problems unless the floats are out of spec. did you check the floats ?
Actually now I have the number. Are 346 heads 79cc.is the transmission kicking down to a lower gear at wot ? were the heads ported for the 2.14 1.81 valves in the 516 heads ? heads could be a big problem if not done right even done right with the bigger valves and porting it has to hurt torque. the 800 AVS2 won't be causing you these problems unless the floats are out of spec. did you check the floats ?
there are open chamber heads they can't be 79cc can they ?Actually now I have the number. Are 346 heads 79cc.
Closed chamber...there are open chamber heads they can't be 79cc can they ?
Ya bad cam all around for this. Like was saying, not doing 4.10 and 4500tc...nopea new cam would be good with high lift and less duration @.50 the 509 was [email protected]. it will get your cylinder pressure higher and more torque. plus knowing it's degree in. sometimes the timing chain and gears are messed up.
am confused the 346 was made from 1971-1973 and are opened chambered.Closed chamber...
Yuup...ur right ans correct. And 3500 stall wont.kick in that high either cause the torque curve on engine is meased. Not good.not sure the cam is your only problem. 509 should turn on at 3500-3800 rpms. if i read right your running a 3500 rpm converter with 3.23 gears that's not good.
But I'm his defense, he was getting advice from a race engine builder that built my tranny. He wasn't listening.....lolYuup...ur right ans correct. And 3500 stall wont.kick in that high either cause the torque curve on engine is meased. Not good.
Matter of fact when I do a off line launch it only runs to 3000...cam just won't work. Maybe 20 hrs so will try to sell it and lifters...lol.
My engine guy knew that. But that's why he's sending the new cam etc...just more work for me. But appreciate his support all things considered.
