New guy on board
Docmcg
10:38 AM
Visalia, CA
Decided to join the group over here. Been a member on FABO for a while, thought I’d join here for more suggestions, recommendations, and just general info. I have a ‘65 Dodge A100 pickup I’m putting back together and sometimes get a little confused. Actually it’s more like I forget where things go and mostly where I’ve put things I removed early on.
Welcome, let's see that A100.
Welcome to FBBO from way north & east of you, NorCal Sierras
Welcome from Alabama, plenty info here.
Welcome from west of you where the a/c is always on, courtesy of nature.
Welcome aboard FBBO from a fellow A100 pickup owner..... in New Zealand. :thumbsup:
:xscuseless:
Thanks for the warm welcome guys and gals. I’ve only got one good picture of my truck. I’ll be adding more as time goes on. I’ve done a fair amount of work on it over time, but have quite a ways to go. So far I’ve pulled and rebuilt the motor (slant 6), swapped from 3 on tree to 727 auto, fabricated front and rear bumpers (originals are next to impossible to get). I removed the solid I beam axle up front and installed IFS w/rack and pinion and added electric power steering. Out back I removed the leaf springs and fabbed up my own parallel 4 link and panhard. Using air bags in the back and coil overs in front. Just recently I got a set of 15x7 Cragar SS with 3 bar spinners. They’re gonna look great for sure. I’ll keep updating as I go along. Again thanks for the welcome,Steve.IMG_0297.jpeg
Care to share any pics or part numbers you used? Always curious. :thumbsup:
Welcome to FBBO from Georgia.
Parts for the electric power steering were scavenged from the scrap yard. Best place for it in a “kit” are from a place online called epowersteering.com. Nice stuff and knowledgeable people. My independent front suspension was a system put together from Chris Allstons Chassis works. They helped me quite some time ago. The rear suspension is a home fabrication I did myself. Had a pair of air bags sitting around from an earlier project and decided to use them. I may put an onboard compressor and self leveling later , but for now just manual fill. Truck still sits 2-3 feet off the ground waiting for completion. One of these days! Wanted to put a set of these on it IMG_2936.jpeg
but opted for these instead
Welcome aboard from Ohio.
