Do you still have your old carb? Is the new 750 dp manual secondaries?
I ask because back when ...... I listen too what I was told with a build(top end). Not knowing I put on a 650 DP DF Manual sec. Which was too much fuel with stock converter off the line.If you still have your old carb bolt it up and see what you get. Won't cost you anything, maybe a gasket.
The MSD won't hurt, I wonder about the cam . Might not be what you want for your app. I don't like the low vacuum ,Have you put a vacuum guage on it ? Whats the pull? I would start there. You can throw alot of money at it
. The cam had been set to +4 degrees, when I swapped the chain I put it back to 0..
I like gauges that are NOT made in ChinaI'll buy a gauge and check. Any specific ones you recommend?
Also, I'm sure how to exactly use a degree wheel? Will a comp cam degree wheel come with directions?
How do you know the compression is 8.5-1? Did you CC the heads and measure deck clearance? I would bet not if you don't understand degreeing a cam and don't own a compression gauge. Lots to learn here. Go slowly. You need to get good data for diagnosis or the results are worthless. The best you can do now is compression test it. My bet is 125 psi or less. Advancing the cam may help. But if you didn't degree it you have no idea if it is advanced, retarded or straight up. There's a great deal to learn from the results of this build. The bottom line is a big cam, low compression ratio, big carb, tight converter, high rear axle ratio won't be very quick. None of it matches up well. It can be band aided and get better. Step by step.
Doug
