CloedFL
Looking for some help or advice
Engine: 383 1970 on my Charger
Trying to get the pertronix with ignitor module 2 running but even after a replacement distributor, a 3rd cap and rotor it wont distribute the spark
Facts:
- 12V on the coil and 10.9 while cranking
- matching coil mounted with 0.6 ohms, no ballast resistor
- wiring all properly as confirmed by Pertronix
- if i hook up the timing light on the coil to distributor wire, my timing light is flashing
- timing light hooked up on any of the spark plug wires, no flashing
- coil to distributor wire removed and positioned to a ground- spark
Coil to dist wire removed - sparks from the coil
- 3 different coils tested all with 0.6-0.7 ohms
- hotwired the coil directly from the battery - still the same
I cant imagine that 2 distributors and 3 caps and rotors are faulty - but still i dont get any of the distributors to do their job and distribute haha
Any advice on what could be wrong?
Facts:
