Logan Hughes
Calling all Mopar BB gear heads for ideas/suggestions. First some background. We did a complete rebuild on my 440 2 years ago and I have about 2,500 miles on it. (Build details covered in earlier posts.) The cam is a CompCams XE-268H with Sealed Power HT976 hydraulic lifters. I went with the stock valve train and inspected everything for wear. I expected a noisier valve train due to the rapid ramp rate and also based on various forum comments. However, I have a definite tick, tick, tick! It is engine speed related from idle to full speed. I checked my fuel pump rod and it was worn badly. I hoped after replacement, that would be the cure. NOT! I'm going to pull the valve covers and re-inspect the rocker shafts, stamped steel rockers, and pushrods. Am I on the right track? Also, I am running Mobile 1 10W30 with Lucas Zinc additive and I'm going up in oil weight with my oil change. So, let me hear your suggestions/ideas. Thanks in advance for y'alls feedback.
